Getting XP Home to remember network logon details
Dr Who
Postby Dr Who » 20 Sep 2008, 16:27
I have just set up a NAS drive (attached to a router) and it appears on my network. To access it I need to supply a user name and password. On Pro it remembers it and on Home it doesn't. I remember a hack going round that enabled Pro features on a Home install (something like this http://mikedopp.com/hackxphome.html) but seems a bit drastic just to enable Home to remember a couple of passwords. Anyone have any other tips, work rounds, etc.
Re: Getting XP Home to remember network logon details
Postby Johnmcl7 » 29 Sep 2008, 02:27
This is one of the fundamental differences between Home and Pro which can't be easily bypassed as far as I'm aware.
Have you considered using net use? You could set this as a batch file to autostart, I find it's a bit more reliable than using map network drive with a different user account. I'm assuming it's shares you're connecting to? An example command to map the share to the Z drive would be:
net use Z: \\servername\share /user:servername\user password
Dr Who
Postby Dr Who » 29 Sep 2008, 09:25
Cheers John, that batch file should do what I need.
Soup4
Postby Soup4 » 29 Sep 2008, 12:56
Dr Who wrote:I have just set up a NAS drive (attached to a router) and it appears on my network.
Which one did you go for, Ras? I've been looking around for one myself. Been told to avoid the WD MyBook as it's slow and read that some of the Buffalo units are very tetchy in RAID0/1 configuration.
Decisions, decisions..
Soup
lukeireland
Postby lukeireland » 29 Sep 2008, 18:20
Soup,
I have a LinkStation Mini. No issue with RAID and the remote access via the web works well. Very quiet too with no speed issues.
http://www.buffalotech.com/products/net ... tion-mini/
Luke Ireland
Soup4
Postby Soup4 » 30 Sep 2008, 06:22
Cheers, Luke - I'll take a look!
EDIT: Ordered. Reviews are good and it's DNLA which I guess means it can stream to the PS3, not a requirement for me but definitely a bonus as is accessing the files from any web browser :)
Soup
Dr Who
Postby Dr Who » 01 Oct 2008, 10:02
Johnmcl7 wrote:This is one of the fundamental differences between Home and Pro which can't be easily bypassed as far as I'm aware.
John, would it be possible to use the same batch file to open an Explorer window? Instead of running at start up could I just double click an icon on the desktop to login and then open the directory in Explorer? I don't really play with batch files these days.
Postby Johnmcl7 » 01 Oct 2008, 18:03
No problem, add a second line to your batch file:
"C:\Program Files\Internet Explorer\IEXPLORE.EXE" Z:
That's for Win2k/IE6, may need a slighe modification for your system.
