Window open upon start-up (XP)
Dax_Inside
Postby Dax_Inside » 12 Aug 2009, 12:11
Hi guys
Ive just installed C&C generals on my asus eee 1005ha. It was from a backup source.
The game has installed into a folder under the c drive called 'Program', instead of the more normal program files.
The game works fine but for some reason when i start windows the window 'program' in windows explorer is open. Its not a major problem but its quite annoying.
Any ideas how to get rid of it? theres no mention of it in msconfig and ive run a regcleaner aswell.
Thanks in advance for any help.
Re: Window open upon start-up (XP)
Postby jurassicjim » 12 Aug 2009, 13:45
Perhaps a reinstall and make sure the game installs in program files?
Dax_Inside
Postby Dax_Inside » 13 Aug 2009, 00:37
I might try that tomorrow. wont that just make the program file window open instead though? one way to find out i guess.
Postby jurassicjim » 13 Aug 2009, 13:21
Dax_Inside wrote:I might try that tomorrow. wont that just make the program file window open instead though? one way to find out i guess.
Yeah, its not a very technical solution, but would be what I would do :)
steffcip
Postby steffcip » 13 Aug 2009, 13:29
I am sure there is a reference in registry somewhere
Dax_Inside
Postby Dax_Inside » 14 Aug 2009, 00:24
I reinstalled it in program files and it doesnt come up any more.
Thanks for the advice :)
