Novatech X70 GTX Pro Review
Postby henrybutt » 13 Jul 2009, 01:49
The X70 GTX is essentially a refresh of the recently reviewed X70 MV. This update is mainly noticed with the GPU with the upgrade from the nVidia 9800M GTS 512mb to the nVidia 260M GTX 1GB. There is no doubt though that this is still the most powerful 15.4” gaming notebook money can buy which fits in just below the X80 GTX and above the X55 MV.
Specifications:
• Screen: 15.4” WSXGA+ 1680 x 1050 (X-Glass)
• Processor: Intel Core 2 Duo P8700 (2.53GHz, 1066MHz FSB, 6MB Cache)
• Memory: 4GB DDR3 Ram
• Storage: Fujitsu 320GB HDD (7200rpm)
• Optical Drive: DVD+/-RW
• Wireless: Intel 5100 AGN + Bluetooth 2.0
• Graphics: nVidia 260M GTX GDDR3 1GB
• 2 Mega Pixel Web Camera
• Battery: 8 Cell
• Dimensions: 364mm x 269mm x 41mm
• Weight: 3.2Kg with 8-Cell Battery
• Windows Vista Home Premium
• Retail Price: £1378.85 inc. VAT (at time of review)
(note: spec has now changed to P8800 and 500GB hard drive at same price)
Build and Design:
The X70 breaks away from the all too common glossy plastic finish of many notebooks on the market today, with the only trace being found in the small area around the keyboard. For the remainder of the notebook, a sleek brushed black (anodized) aluminium finish which is surrounded by a silver edge which really makes it stand out from the crowd. One very noticeable thing is the complete lack of branding on the notebook. There is nothing, except a small sticker on the underside of the notebook which says that Novatech actually build this laptop.
As far as build quality goes, the X70 is nothing short of excellent. There is no keyboard or palmrest flex whatsoever and as usual with Clevo based notebooks, everything seems very well put together. Thanks to the rigid aluminium lid, there is no show through whatsoever when pressure is applied to the back of the screen and the screen hinges seem very robust with no wobble whatsoever. One slight drawback of the hinge design is that it can only be put back to around 45 degrees and no further, although this isn’t to limiting.
The addition of the more powerful 260M GTX card means that Novatech has changed the cooling design of the laptop and has now opened up the previously blocked intakes on the bottom, meaning that it isn’t really possible to use this on your lap.
Screen
As far as notebook screens go, the display in the X70 is sharp and bright with good viewing anglesThe quality of the screen is greatly improved by the X-Glass coating, which is not over-reflective like many other notebooks but is enough to give the extra clarity and improved contrast of such a coating. If it wasn’t for the stuck pixel, this screen would match the high standards set by the rest of the laptop. The screen would also benefit from LED backlighting as it is not as bright as the superior screen of the X80. I have to say that the X70 GTX has a noticeably clearer and brighter screen than the X70 MV and is a welcomed improvement to the notebook.
It would have been nice to see Novatech using a 16:9 screen rather than the 16:10 as this Notebook is so geared up for high definition playback, although they are limited somewhat by what is offered by the ODM
Speakers:
The speakers on the X70 are about average as far as notebooks go, being adequate to watch a movie but for anything more, you really need external speakers or headphones. The placement of the audio jacks could be better, being right next to the hard drive which causes some interference in the audio output, but this hardly noticable over music.
Processer and Performance:
The X70 sports the Intel Core 2 Duo P8700 processor which runs at a healthy 2.53 GHz. This provides ample power for almost every task that you throw at it and combined with the powerful nVidia 260M GTX graphics chip, provides stunning frame rates in the latest games, while has a low TDP at 25W so that it is more efficient than the slightly more powerful processors which helps improve the battery life. It is noted however that the X70 GTX Pro at standard specification has a less powerful processor than the X70 MV. There is not a massive difference as the CPUs are clocked the same however the cache isn’t as large. Novatech have chosen to use a Fujitsu 320GB 7200rpm hard drive in this model which is currently the biggest 2.5” hard drive available in this speed, although if you require the optimum performance, you can upgrade to a Solid State Disk for around £50. As mentioned previously, the X70 features the nVidia 260M GTG graphics chip. This is currently the second most powerful mobile chip from nVidia which, coupled with the X-Glass screen provides stunning graphics and frame rates in the latest games.
Benchmarks
CPU-Z
GPU-Z
Windows Experience Index
HD Tune
3DMark 05
3DMark 06
Super Pi
Cinebench R10
Heat and Noise
Unlike its bigger brother the X80, the X70 uses a single fan cooling design which seems to be far superior in most ways. Noise is reduced massively over the two fan design, and even when gaming, the fan noise is not intrusive at all, and if complete silence is required, there is a silent mode, activated by a button above the keyboard which clocks down the system so the fan isn’t required. It is noticeable however that the cooling system is louder than in the X70 MV although not by much which is likely to be down to the revised bottom panel design.
Keyboard and Touchpad
The keyboard included is above average as there is no flex whatsoever and the responsiveness is great. The keyboard is noticeably quieter than that of the previous generation X70 and cannot really be faulted.
The touchpad on the X70 is well designed and has lost the blank plastic to a finger print reader which is a welcome addition. Sadly this seems to have affected the buttons slightly as they occasionally get stuck down and are reluctant to pop back up. Apart from this though the touchpad has a good texture and is generally nice to use.
Input and Output Ports
The X70 has almost every connection you could want for a laptop, including both HDMI and E-Sata connections. The only port that would be welcome is a standard VGA port for use with older displays / projectors, however there is a DVI adapter provided for this. Also t placement of the audio connections could be better as they are on the front which is useful for headphones but can be a little annoying when connecting to speakers.
All descriptions are from left to right
1. Optical Disk Drive
1. Expresscard Slot
2. Memory Card Reader
3. 2 x USB 2.0 Port
4. RJ-45 Gigabit LAN port
5. RJ-11 Modem Port
1. Headphone Jack
2. Microphone Jack
3. SPDIF Jack
4. Mini Firewire Port
1. DVI-D Port
2. HDMI Port
3. USB 2.0 Port
4. USB 2.0 / E-Sata Port
5. Kensington Lock Slot
Wireless
The X70 makes se of the Intel Wifi-Link 5100 AGN card which has an excellent range and achieves decent speeds even when only using a G connection. The laptop also features Bluetooth and has a slot available for an HSDPA card (not available at point of review).
Battery
The battery life of the X70 is actually surprisingly good for a notebook of this nature. If you are conservative and use the Silent Mode, you can get almost 3 hours or useful life, although when gaming you will reduce this to nearer the one hour mark. It would have been good to see a binary graphics option available like on the rival Alienware M15X but the Silent Mode does compensate for this a little.
Operating System and Software
My review model of the X70 had Vista Home Premium 64bit installed, however it is available with most flavours of Vista and XP or without an operating system at all. Sadly there was no operating system disk included, although they are available from Novatech upon request The only pre-installed software that the X70 ships with is a 60 day trial of Microsoft Office and the only disk which comes with it is a Driver disk which also contains a .PDF version of the user manual.
Customer Support
Novatech provides some of the best customer support I have ever experienced from a computer manufacturer. Every issue I have had with the laptop I purchased from them has been dealt with in a professional and efficient way, and I have been nothing less than 100% satisfied with it. Novatech have both phone support and a live chat which I have tried out and both seem to be very helpful. I have to say their live chat is on a whole different level to that of Dell. As standard, all Novatech laptops come with a 12 month return to base warranty, however for the cost of around £40, this can be upgraded to a 2 year C & R warranty which I think is a must have.
The Novatech X70 is the best laptop currently available if you are looking for the optimum balance between gaming performance and portability, being far smaller than most similarly configured 17” notebooks and only slightly bigger than more mainstream 15.4” notebooks. The main downsides is the heat generated by the hard drive, however this is guaranteed under warranty so isn’t a massive problem.
Pros
• Sleek design with a premium finish
• Desktop performance graphics in a 15.4” form factor
• Available with a variety of operating systems or none at all
• Silent mode which improves battery life considerably
• Great build quality
• Amazing screen quality
Cons
• Hot hard drive
• Touchpad buttons stick down
Thanks to Chris and Charmaine at Novatech for organizing this review unit for me
Re: Novatech X70 GTX Pro Review
Postby Johnmcl7 » 13 Jul 2009, 10:46
Thanks again for another reviews, I'm curious are the speakers any better than the original chassis? I found them awful on the original model as the audio was so thin and so quiet that even ultralights I've used have better speakers. I had the same problem with the touchpad buttons sticking down on the X70 I had which was one of the reasons I sent it back.
Postby Tappy » 13 Jul 2009, 14:18
Glad to see Novatech are offering more processor options now on the website, including some quad cores. I know you told me they would be flexible on configuration if I called them up, it's just nice to see it in writing. Decent price too - for the same as what I paid for the x620 about 8 months ago, you'd get a T9900 and that GTX260 in the Novatech (incidentally Rock seems not to have changed their price at all... maybe tomorrow eh?!)
EDIT: Ah, it's the Rock logo that must cost so much - still no Novatech one ;)
kingosticks
Postby kingosticks » 13 Jul 2009, 14:55
Unless its my browser being weird I think some of the benchmark pics are muddled up. The 3d mark05 is the Windows Experience Index one. But nice review, I'd like a silent mode for my laptop.
Postby Johnmcl7 » 13 Jul 2009, 16:09
They weren't showing for me earlier but you're right, the HD tune/Superpi/3Dmark are mixed up or missing.
poor_man_jim
Postby poor_man_jim » 13 Jul 2009, 18:52
Cheers for the informative review. Shame about the price though, ouch!
Novatech X80R [Clevo M570RU-U]: 17" Gloss 1920x1200, Intel T9300, 4GB RAM, 500GB WD Scorpio Black HD, 512MB 8800M GTX
HP MicroServer N36L - 3 x WD20EARX - Linux Mint
Samsung NC10: 10.2", Intel N270, 1GB RAM, 160GB HD
Postby Johnmcl7 » 13 Jul 2009, 19:42
Pictures are all showing fine for me, any idea how the silent mode works? I assume it's doing something more than just clocking the processor down to its lowest processor state?
There's an error in your hard drive part, the 320GB isn't the biggest 7200rpm notebook drive available as there is a 500GB 7200rpm drive.
Postby henrybutt » 13 Jul 2009, 22:25
I have now updated the pictures so that they actually show the correct benchmarks. The silent mode does work by clocking down the CPU and GPU until there at a level where they produce minimal heat which can be cooled by the fan on minimum or passively. The speakers are exactly the same as the originals... very little has been changed except the GPU, screen, fingerprint reader and addition of support for quad core CPUs.
Postby Johnmcl7 » 14 Jul 2009, 00:45
So the silent mode is no different to the OS's own power save mode then? (as with Uniwill) I wondered if it was doing something with the chipset to get the power down further than the OS would be able to do. It's disappointing to hear they've not made any real improvements to the chassis as I felt it really needed them in some areas.
Postby Advocate » 14 Jul 2009, 09:12
Another good review - ta henrybutt :)
Postby henrybutt » 14 Jul 2009, 18:10
I'm pretty sure that the silent button clocks down the CPU and GPU on a BIOS level so does do more than power saver mode
Postby Johnmcl7 » 14 Jul 2009, 18:43
The OS also clocks both components down through the bios (it can't do it any other way)- I can't see how it's clocking them down any further as they're both standard parts which Clevo have no control over and they shouldn't be undervolting them below their own power management specification. There is further power saving to be made on the chipset though as Clevo produce the motherboard and previously they had some tricks with dynamic FSB clocking to get the power down on battery power when Speedstep didn't support it at the time.
Uniwill's power saving mode was disappointing as all it did was clock down components in the exact same way the power saver mode through Windows did.
Postby Tappy » 15 Jul 2009, 00:41
You know, until you started discussing it, I had never pressed that button - I assumed it was a mail shortcut because it had an M on it. The nearby button with the letter on didn't raise my suspicions at all!
Postby Johnmcl7 » 15 Jul 2009, 01:07
I've just noticed that's a DVI-I port rather than DVI-D (which wouldn't make much sense), seems an odd choice to have the DVI and hdmi connections rather than an hdmi and vga connection. As mentioned above, this is the 500GB 7200rpm drive:
http://www.seagate.com/www/en-us/produc ... us_7200.4/
poor_man_jim
Postby poor_man_jim » 17 Jul 2009, 18:22
Aha! Better value can be found at Overclockers it seems with their pre-order base model priced at a more modest £997 inc VAT;
http://www.overclockers.co.uk/showprodu ... =LT-004-OE
Same GPU, a slower 2.0GHz CPU (the 2.53GHz P8700 though, an affordable £60 upgrade), no Blu Ray (which comes as standard with the base X70 GTX; shown if you hit the Modify button) and OS but 2 years warranty as standard.
