DNS errors GRRRR!
Malice
DNS errors GRRRR!
Postby Malice » 07 Sep 2008, 02:07
Need your help guys. My internet is down 60-70% of the time due to DNS errors. I've done a DNS flush using cmd prompt, that didn't help. Resetting the router normally does the trick, but this isn't always possible during the day as other people will be online etc
Anyone have exp with such things?? It's REALLY starting to annoy me. Seems like I'm the only one in this house that has this issue. There must be something wrong my end??
PS - As I type this my housemate is getting jiggy in the hallway...joy
Empty space for rent $5!
Re: DNS errors GRRRR!
Postby Johnmcl7 » 07 Sep 2008, 02:48
Have you tried using a different DNS server than your ISP's?
Soup4
Postby Soup4 » 07 Sep 2008, 09:34
It sounds like your computer and router are having DCHP issues; DNS server IP parsing is usually the first thing to go.
I'd suggest you manually configure the two DNS server entries for your network connection. Google "DNS server list" and you'll find hundreds of pages containing thousand of public DNS servers, alternatively you can simply manually configure the IP addresses for your ISP's DNS servers because it doesn't sound like your ISP's servers are at fault, just the routing of host names from your computer trough the router to the DNS servers.
Soup
Malice
Postby Malice » 07 Sep 2008, 13:38
OK. I manually entered suggested DNS servers. Will let you know how I get on. Cheers for the help.
Malice
Postby Malice » 08 Sep 2008, 02:20
Meh! still happens. This time it effected my housemates too. Two of them come into the front room to reset the router. Maybe the router is on the way out? Might just pick up a cheap one and try that.
james
Novatech PR
Novatech PR
Postby james » 08 Sep 2008, 08:51
No firmware updates avail?
Xeon 5050 | Intel S5000VSA | 2GB | 750GB 7200rpm | CM Stacker 830 | ATI X800 AIW | Hyundai W241D 24" | 70GB REV
Novatech m20 | Intel 800MHz | 1GB | 100GB | 3G | 12"
Novatech x80r | X9000 | 2GB | 8800M GTX | 200GB 7200rpm | WUXGA+ | DVDRW
Postby UKIan » 08 Sep 2008, 13:18
Malice wrote:Meh! still happens. This time it effected my housemates too. Two of them come into the front room to reset the router. Maybe the router is on the way out? Might just pick up a cheap one and try that.
Could be, I've had that before.
Postby BinnsY » 12 Sep 2008, 13:18
Can you manually change the DNS server adresses in the router settings? If so might be worth changing those to the openDNS servers and see if that helps.
Postby EviL Ras » 12 Sep 2008, 21:25
The addresses of the OpenDNS servers are 208.67.222.222 for a primary DNS server and 208.67.220.220 for a secondary server.
Postby Replicant » 28 Jun 2014, 12:07
Digging up this old thread.
Major problem with BT DNS servers this morning so was considering changing to opendns of someone else instead. Will have to so this within each machine as bthomehub setting cannot be altered.
Any recommendations or pitfalls to doing this?
Postby jurassicjim » 28 Jun 2014, 16:11
I saw bt broadband was down for a few people in the news. Is this another issue replicant?
I'm switching from sky to BT infinity 2 on the 10th, so I hope not...
Postby EviL Ras » 28 Jun 2014, 16:30
bt infinity 2 is EPIC!!! We get 76mps in central london on a good day (high 30's on a busy night). Its given us very little issues (other than the dual band wireless router, as the wifi printer has to be on the 2.4ghz, and my laptop loves the 5ghz range! so i split the ranges!).
We also got the BT home wifi extender 500. Uses powerline tech to connect a wireless hub in the front room to the main ADSL stuff in the bedroom. Works an absolute treat!
Postby Replicant » 28 Jun 2014, 19:07
I have had Infinity 2 for over a year and it's great most of the time.
Today there was a DNS failure which affected them nationwide for about 3-4 hours.
I just changed my Surface RT's DNS to opendns and all was fine.
Postby Johnmcl7 » 28 Jun 2014, 20:42
Replicant wrote:Digging up this old thread.
The biggest annoyance is going to be the fact that you can't change it on the router, if you want to change again it means changing all the devices and on some it can be quite fiddly to get manual DNS settings in. Since the DNS should work whatever location you're at there's not the hassle of having to change each time you leave the house. The only other issue is if you're using any internal DNS resolution for devices based within the house (such as a media server) although I'm assuming in most cases you're just wanting to go straight out onto the internet?
