Anyone here using USB-C?
Postby Johnmcl7 » 13 Sep 2016, 18:28
I've just bought a Latitude 11 which is my first USB-C powered device and its main purpose is a spare PC at work so I'm thinking having a charger there will be handy however with it being USB-C, I'm wondering if I should look into something that can quick charge the phone as well as power the tablet particularly as the Note 4's replacement will likely be USB-C. At the moment I've been using Aukey so I'm wondering if there's something similar although I'm wary of the dire warnings about only using official Dell supplies when I know there's been issues with USB-C products not meeting spec in the states and damaging the devices.
Postby EviL Ras » 13 Sep 2016, 21:52
I favour anker for all my charging needs. And surely as USB-C is now a standard, any charger should work?
Postby Johnmcl7 » 13 Sep 2016, 23:18
Although USB-C is a standard, a lot of companies don't seem to be following the standard correctly:
http://gizmodo.com/a-google-engineer-is ... 1742719818
Also HP for example only support their own USB-C chargers:
http://www.pcworld.com/article/3017182/ ... dream.html
I've looked at Anker who have this product:
https://www.amazon.co.uk/Anker-Premium- ... op?ie=UTF8
The first catch is that it doesn't support QC, if you want QC you need an alternate product which surprise, surprise doesn't support USB-C :( The reviews are mixed for USB-C charging for higher power devices like the Core-m powered Latitude 11 as well, it seems you can't just use a normal USB port with a USB-C cable if you want to charge at the correct rate.
The more I read, the more I'm thinking it's probably easier just to go with a Dell charger as it's a lot cheaper than the Anker which doesn't do QC anyway.
Postby robbo » 13 Sep 2016, 23:40
Before I bought my anker usb charger I looked into the USB-c and QC options as well for future proofing but ran into the same "it doesn't do both" so just plumped for a standaed usb port.
And no, never used USB-c.
Postby Tappy » 14 Sep 2016, 09:26
My Windows 10 Mobile is USB-C, and yeah, I am wary about using non-official chargers. I only have one charger, which I use in work, but I have lots of Wireless chargers at home and I figure I'm more likely to need a quick charge in work.
Postby jurassicjim » 14 Sep 2016, 11:26
You could potentially buy the products from the Google Play store. I have a few as I got the Nexus 6p. Needless to say they all work perfectly, feel very well built and great returns service and policy with Google.
https://store.google.com/collection/accessories
Postby Tappy » 15 Sep 2016, 09:21
Ooo, Mrs T has just bought a Nexus, so she must have a USB-C. That's useful, we can share chargers again.
Postby matt » 15 Sep 2016, 09:56
what's USB-C, is it like a cheap version of lightning?
Postby jurassicjim » 15 Sep 2016, 10:33
matt wrote:Source of the post USB-C
Just a better version of lightning. I wish Apple would ditch the lightning port.
Postby Johnmcl7 » 16 Sep 2016, 19:41
Aside from the Google stuff being pricier than the Dell kit, it doesn't support QC - it seems USB-C and QC are mutually exclusive.
Postby jurassicjim » 19 Sep 2016, 09:10
i get quick charging on my phone with the Google chargers. Are there a couple of standards of it?
Postby Johnmcl7 » 19 Sep 2016, 14:46
QC is a Qualcomm standard which came before USB-C.
Postby jurassicjim » 20 Sep 2016, 10:04
So is all USB C technically quick charge?
Postby Johnmcl7 » 20 Sep 2016, 18:42
No, USB-C is technically just the connector so it can be USB2 spec. Even USB 3.1 with a type-C connector doesn't guarantee anything as there's different power levels and capabilities that can be handled on the port.
Postby csteff » 21 Sep 2016, 11:28
I have 1+3 with usb-c
and using an aukey with QC 5 port charger and charges pretty fast
1+3 specs says: Dash Charge (5V 4A)
Users browsing this forum: No registered users and 8 guests
