Fanless PC
steffcip
Fanless PC
Postby steffcip » 01 Jan 2016, 18:43
I may sell this PC if anyone is interested
it is great but have other priorities
Fanless PC
Postby jurassicjim » 01 Jan 2016, 22:58
How much and what are the dimensions?
Thanks
steffcip
Fanless PC
Postby steffcip » 02 Jan 2016, 01:01
total price of all components at the time of order (al bought new in Sept and SSD in Oct 2015) £650 (I had some special discounts which I could have used on other orders but with the discounts £600)
I would want less 10% and I will pay postage as well
It may seem much but i7/ssd/16gb and fanless is a great pc :)
steffcip
Fanless PC
Postby steffcip » 02 Jan 2016, 01:12
lower specs but with case from same range/same manufacturer 1k+
http://www.amazon.co.uk/Sedatech-UC0314 ... 143F3CI8HE
Fanless PC
Postby jurassicjim » 02 Jan 2016, 12:44
Yeah, it's really nice. But out of my price range for what I need an extra PC for though. Good luck with eBay sale!
J
steffcip
Fanless PC
Postby steffcip » 23 Jan 2016, 12:01
I upgraded the cpu to i7-5775c and will not sell it anymore BUT
I have 3 pcs similar/same silent no fans
- I will sell one with the i7-4770s but the rest is brand new only the cpu is used for less than 6 months and added dvdrw - similar here with the t version of the cpu which is lower benchmarks sold to 1k+ http://www.amazon.co.uk/s/ref=sr_st_pri ... -desc-rank
- 2x same specs more or less but with i3-4130t (which is sold at £90 and has 4k+ benchmarks which is still great and of course you can upgrade later to i5/i7) with same case, same motherboard, 8Gb ram, one with blu-ray and 1 with dvdrw, 120gb SSD + 500gb/1tb hdd at around £500 - need to do my calculations on costs
Anyone interested? I will confirm exact specs but can confirm the i3 worth at least £600+ and Sedatech sells on Amazon for £900-1000 same specs
steffcip
Fanless PC
Postby steffcip » 23 Jan 2016, 16:39
Specs for the 3 PCs I have for sale
1st one is similar to http://www.amazon.co.uk/Sedatech-Evolut ... B014T7P8OW which is £1200 on that link but mine is even better specs: CPU is i7-4790S (S is better than T version), has 2000gb/2Tb HDD instead of 1000gb, the rest is the same 120gb SSD, 8gb ram, combi blu-ray drive with dvdrw, usb 3.0, wifi, bluetooth, same case Streacom FC8 Evo which is £150 (http://www.ebay.co.uk/itm/ST-FC8S-EVO-S ... SwDwtUq-Tb but mine is black), good motherboard which cost £90 http://www.amazon.co.uk/MSI-H97I-AC-LGA ... SI+H97I+AC. Also Windows 8.1 Pro license (free upgrade to Windows 10). NO FANS at all, completely silent. That amazon link shows lower specs for £1200. Real build cost is about £750-800. I will sell it for £650 inc postage. It is brand new except the CPU which I bought it in Sept 2015.
2nd same case, motherboard, 120gb SSD, 1tb HDD, 8gb ram, dvdrw, win 8.1 pro license, bluetooth, wifi - all this is brand new + the CPU is upgraded to i5-5675C which has very good integrated graphics iris pro 6200 (cpu alone is £220) - price £600 (only CPU is used few months old)
3rd same case, motherboard, 120gb SSD, 500gb hdd, 8gb ram, dvdrw, CPU is i3-4130T (4k+ benchmarks), bluetooth, wifi, win 8.1 pro license (free upgrade to win 10), brand new £500 delivered
easy to upgrade ram, hdd/sdd, replace dvdrw with bluray or even upgrade the cpu to any socket 1150
Fanless PC
Postby EviL Ras » 23 Jan 2016, 18:14
Looks awesome!
Ghost - MSI GS60 Ghost Pro. 15.6" 1920x1080 LED, i7 4710HQ 2.5 (3.5ghz turbo), 16gb DDR3 1600mhz RAM, 3GB Nvidia GTX870M, 2 x 128gb SSD, 1Tb 7200rpm HDD
Born 10/06/14
steffcip
Fanless PC
Postby steffcip » 07 Feb 2016, 02:21
i7 old but I still have 2 left, one with i3 as above and one upgraded to i5-5675c which is a great CPU (and blu-ray/dvdrw drive)
Fanless PC
Postby se99paj » 15 Feb 2016, 17:51
Hi Steff - So recently found out that the FC5 supports full-size motherboards, and it has peaked my interest in a Streacom case again and wanted some advice.
I need to replace my aging Shuttle PC that I use as a HTPC as the case is very noisy, Streacom seem to be the best option and the FC5 will fit underneath the TV perfectly. I haven't done anything in the past as the cost of a mobo/memory/CPU/Case/PSU was going to get expensive, but as the FC5 now supports a fullsize mobo it means I can reuse an older motherboard (With memory and CPU) and only purchase a case and PSU.
Can you provide any build advice? I'm fairly confident building a PC but the Streacom cases seem to be a bit more complex, also which power supply did you use? can't help think those nanoPSU's look a bit fragile.
steffcip
Fanless PC
Postby steffcip » 18 Feb 2016, 09:19
Yes i will reply later
I upgraded the i3 to i5 so now have 2x i5 silent pcs if anyone interested
Both with 16gb ram and bot with 120gb ssd and 1tb 2.5 hdd
steffcip
Fanless PC
Postby steffcip » 18 Feb 2016, 09:20
se99paj wrote:Source of the post Hi Steff - So recently found out that the FC5 supports full-size motherboards, and it has peaked my interest in a Streacom case again and wanted some advice.
What mobo and cpu you have?
Fanless PC
Postby se99paj » 18 Feb 2016, 10:21
My motherboard is the Asus P5KPL-AM (https://www.asus.com/Motherboards/P5KPLAM/) - I need to get the measuring tape out and compare against the building guide on the Streacom website to make sure it will fit. I realised that other day that this also has onboard graphics which is a bonus as I thought I'd have to use the PCI slot for a Gfx card.
I've got 2 processors to choice from:
Intel Core2 Quad Q6600
Intel Core 2 Duo E7400
I know they're old CPU's but they still work fairly well, I only upgraded my desktop PC last year and I was using the quad core with this motherboard until then.
I compared the CPU's here: http://cpuboss.com/cpus/Intel-Core2-Qua ... -Duo-E7400
At the moment I'm thinking the Core 2 Duo would be my better option as it has a lower power usage, the TDP is 65W which I think Streacom recommend as the maximum.
steffcip
Fanless PC
Postby steffcip » 20 Feb 2016, 07:47
Yes use the 65w cpu
for PSU: either 150w should be enough http://www.quietpc.com/st-nano-psus (no watts left for extra video card) or 240w http://www.quietpc.com/st-zf240
or pico psu http://www.kustompcs.co.uk/acatalog/info_1667.html + http://www.ebay.co.uk/itm/261313547526 (cheap power brick but works, I bought 3 from my silent pcs I sold)
the heatsink is not that difficult to install (the most "difficult" job for this build), there are youtube guides I am sure
Fanless PC
Postby se99paj » 24 Feb 2016, 16:51
Thanks Steff - will let you know how I get on when I come round to the build.
