Windows 10
Re: Windows 10
Postby Replicant » 29 Jul 2015, 10:08
My other laptop has downloaded and will be upgraded tonight.
The SP3 only took 30 mins to upgrade which was pretty good I thought.
Re: Windows 10
Postby matt » 29 Jul 2015, 10:25
the parents PC is criminally slow and reading the other thread, the idea of a SSD + win10 updgrade make sense.
would I need to:
install new SSD
install win 7
free upgrade win 10?
plug in old HDD and copy old documents / photos to new SSD?
Re: Windows 10
Postby EviL Ras » 29 Jul 2015, 12:23
The download simply isnt working for me. i've done all the fixes about wiping the download files and forcing the windows update again, all to no avail. i'm now downloading a 4gb installer from microsofts website to see what that does for me!
Ghost - MSI GS60 Ghost Pro. 15.6" 1920x1080 LED, i7 4710HQ 2.5 (3.5ghz turbo), 16gb DDR3 1600mhz RAM, 3GB Nvidia GTX870M, 2 x 128gb SSD, 1Tb 7200rpm HDD
Born 10/06/14
Re: Windows 10
Postby robbo » 29 Jul 2015, 12:58
Not checked to see what happens with those on the TP or if what I've got is definitely the 'full' release. Minus the 1gb day one patch that is. Will see id my Stream tab gets the upgrade too.
Matt - from my understanding, yes. Will be doing similar once I'm able to download the w10 iso for installing on my laptop using the sdd I bought the other week.
Maybe some download solutions in the comments here: http://www.windowscentral.com/windows-1 ... ger-update
More reviews: http://www.windowscentral.com/windows-10-review
Re: Windows 10
Postby EviL Ras » 29 Jul 2015, 14:26
I downloaded from here: http://www.microsoft.com/en-us/software ... /windows10
took about 2 hours (no idea why as it wasnt downloading anything!) then about 20 mmins to upgrade.
After the upgrade i had to reboot as the mouse didnt work. its working now, but scrolling is now the opposite way to windows 8. grr.
just testing all the software now.
Born 10/06/14
steffcip
Re: Windows 10
Postby steffcip » 29 Jul 2015, 19:24
Scrolling may be as on the mac the default setting which is "natural"?! And I hate...
Re: Windows 10
Postby EviL Ras » 29 Jul 2015, 22:13
yeah, i changed the settings for the touchpad drivers to invert and smooth scrolling and its a hell of a lot better.
The elive stuff doesnt work in photoshop at the mo unless the edge browser is open. apparently this is down to the lack of IE, so Adobe are looking into it.
But other than that, its all looking good.
Cortana however is shiv.. she's useless at doing pretty much everything that i expected her to do! she doesn't understand half the stuff that google does! Dont think i'll be uing her much!
Born 10/06/14
Re: Windows 10
Postby robbo » 30 Jul 2015, 12:42
EviL Ras wrote:Cortana however is shiv.. she's useless at doing pretty much everything that i expected her to do! she doesn't understand half the stuff that google does! Dont think i'll be uing her much!
What have you tried asking Cortana to do? I rarely use it on my phone but when I do it's just simple stuff like set an alarm, create a reminder, ask her to sing me a song etc and that works fine. Not tried it on my laptop.
Failed install using the tool on the Stream 7. Have downloaded the 32 and 64 bit versions as an ISO and currently burning that to disc.
Re: Windows 10
Postby Tappy » 30 Jul 2015, 13:26
Probably doesn't understand Manx.
I haven't had my Windows 10 notification yet. Started up my computer last night and there was nothing this morning. Is everyone supposed to get it, or is it a phased roll-out?
Re: Windows 10
Postby robbo » 30 Jul 2015, 14:30
It's a phased roll-out. You should get it soon enough. PC at work had the notification about w10 a few weeks ago but hasn't started downloading it yet.
Or just follow Ras' link above to download it straight away.
Re: Windows 10
Postby EviL Ras » 30 Jul 2015, 14:42
Well, the trackpad went again last night! but the machine to sleep, woke it up and the mouse had vanished! Plugged in my gaming mouse and rebooted twice. still no love. had to reinstall. but then the scrolling was knackered again! Ran a driver update and its all working again now.
Everything seems to be working well so far. wireless is improving. Battery seems to be longer?
Born 10/06/14
Re: Windows 10
Postby EviL Ras » 30 Jul 2015, 17:12
So the word Acrimonious was used in friends and i thought, "i cant remember what that means". So i asked cortana. After 6 tries it finally recognized my voice and came up with the following result.
I went to the google homepage and without touching anything asked "ok google, what does acrimonious mean?" and it came up with the following result.
So basically google likes me more as it can understand my accent! So think i'll stick with ok google!
Born 10/06/14
Re: Windows 10
Postby Tappy » 30 Jul 2015, 18:37
Exactly the same answer for me on both. Worked first time. It is your voice!
Also, I went to Google.com and had no urge to touch myself. Dunno why you felt the need to share that moment of restraint with us.
Re: Windows 10
Postby robbo » 30 Jul 2015, 18:43
Just tried on my phone with Cortana. First try result:
Likes my accent!
Re: Windows 10
Postby EviL Ras » 30 Jul 2015, 18:46
Took 5 attempts but finally worked, after i turned off the "learn my voice" stuff. Google just works. must have better recognition technology.
Born 10/06/14
