avi to dvd
avi to dvd
Postby csteff » 14 Jan 2010, 13:05
anyone know a good dvd maker from adi/xvid files? no need to create menus or anything fancy
free if possible otherwise paid
Re: avi to dvd
Postby robbo » 14 Jan 2010, 13:46
ConvertXtodvd is a good one I've used before. Did have problems burning to disc a few times so let it just make the image and then burnt to disc using imgBurn.
Is paid for unless you want to go the other route. http://www.vso-software.fr/products/convert_x_to_dvd/
Never really found a good free dvd maker.
Re: avi to dvd
Postby FatIan » 14 Jan 2010, 15:38
I used to use covertxtodvd, but I noticed some dvd players didn't like the discs created. Again using the same method as Robbo, create with convertx and burn with a different progam like ashampoo burning studio or nero. So now I just use nero7. Not come across a dvd player which wouldn't play one created by that. Again not free but nero7 is available the other route with no issues unlike 8 and 9.
Re: avi to dvd
Postby csteff » 15 Jan 2010, 09:30
thanks
Users browsing this forum: No registered users and 14 guests
