Ventrillo/TeamSpeak
Suggestions, thoughts and discussion on the forum setup
Ventrillo/TeamSpeak
Postby Advocate » 04 Nov 2008, 17:59
I know very little/almost nothing about these services but what I do know is that they are a means to communicate with voice while playing games etc.... question is do we have enough bandwidth to host em... and would you mind hosting them for us? ----- for better details etc Binnsy is your man.......
discussed here:
viewtopic.php?f=10&t=803&p=16264#p16264
Muff love mod dudes :iminlove:
Re: Ventrillo/TeamSpeak
Postby csteff » 04 Nov 2008, 20:08
I will ask my friend now...
no idea what's this...never used it...maybe a wiki site?
Postby BinnsY » 04 Nov 2008, 20:09
http://www.goteamspeak.com/
Basically you install the server client then we can all connect to it and its like a big voice chat room.
Postby matt » 04 Nov 2008, 20:15
presumably we can make it private so bandwidth is low?
Postby BinnsY » 04 Nov 2008, 20:21
Yes you can, its quite easy to specify a password in the TS server config.
If you do want help setting this up i have rather extensive knowledge of editing Teamspeak settings, I know very little about Ventrillo though.
Postby matt » 04 Nov 2008, 20:24
I am fully qualified in microphone abuse if that helps.
Bring up the noober cannon!
Postby Fodder » 04 Nov 2008, 20:34
Have used TS for years now, very easy to setup and use. Just keep your mike away from your nose and no whistling!
Postby BinnsY » 04 Nov 2008, 21:27
Looks like teamspeak is winning out :D
Personally even though it is a lot lower audio quality than Vent I much prefer it :P
Postby csteff » 04 Nov 2008, 21:50
1 month testing account
http://ts.cstefan.com:14534/
passwords will be PMd to BinnsY
Postby BinnsY » 04 Nov 2008, 22:00
Ok, the server is up but I'm having problems with the account so it might take me a little while to get it set up.
Postby BinnsY » 04 Nov 2008, 22:11
Ok its now up and running, please PM me for the connection password.
The server address is ts.cstefan.com port is the default 8767
If you dont know how to use teamspeak once you have it installed go to connect, quick connect, and enter the server as ts.cstefan.com, any nickname, and the password that either me or cstefan can give you via PM and you will connect. I will work on getting proper registered accounts set up once the basics are working.
Postby EviL Ras » 04 Nov 2008, 22:55
Time to order a headset then!
Postby Advocate » 04 Nov 2008, 23:00
Downloading and ordering a headset now.... the medusa looks good although there are so many options....
Postby Fodder » 04 Nov 2008, 23:05
I've used both a 5.99 special from game and some plantronics. Both performed fine with TS, but the plantronics are WAYYYY more comfy.
Looking to get some medusas from Santa :)
Postby Replicant » 04 Nov 2008, 23:29
If anyone needs help setting up you can PM me or BinnsY(amongst others) for assistance.
Return to “Site Discussion”
