NSFW Button
Suggestions, thoughts and discussion on the forum setup
Re: NSFW Button
Postby Johnmcl7 » 12 Jun 2008, 10:35
So I'm noticing, good thing they are easy to implement here!
Bryn
Re: NSFW Button
Postby Bryn » 12 Jun 2008, 10:54
Generally my sunday AM drunken rants are NSFW so it's all good.
I still think PC Specs should go above our post count.
Dell XPS M1330 - T7500 / 8400M GS / 2GB / 250GB / WLED / Intel-N / 9 Cell
C2Q Q6600 / 512MB 8800GTS / 2GB OCZ / 580GB / X-Fi
Re: NSFW Button
Postby Johnmcl7 » 12 Jun 2008, 11:43
They can't go in there using the current implementation as it would wreck the formatting, the user info panel is already too big as it's stretching posts as it is.
Bryn
Re: NSFW Button
Postby Bryn » 12 Jun 2008, 12:00
Just to be clear, would the putting of the button there itself wreck the formatting, or the expanding element of the button? Because i've seen them before when they open up in a little window all to themselves..
Re: NSFW Button
Postby csteff » 12 Jun 2008, 12:05
oh that's different what you want Bryn... will try to look into it..
Bryn
Re: NSFW Button
Postby Bryn » 12 Jun 2008, 12:10
I'll try to find what i mean just to clarify. *forum search powar ho!*
Bryn
Re: NSFW Button
Postby Bryn » 12 Jun 2008, 12:13
Here you go..just over halfway down the page under the user '1 got owned'
The page is of no relevance to anything it's just the first i clicked.
Re: NSFW Button
Postby csteff » 12 Jun 2008, 12:18
tried to click on My System but it doesnt work...maybe you need to be logged in to click it?
Bryn
Re: NSFW Button
Postby Bryn » 12 Jun 2008, 12:24
Piss. I'll just ss it.
It's a vbmenu with a simple TD in.
Re: NSFW Button
Postby csteff » 12 Jun 2008, 12:27
ok what about those who have 2-3 systems/laptops?
Bryn
Re: NSFW Button
Postby Bryn » 12 Jun 2008, 12:31
A fair point and one which i can't think of a solution for, other than a second column, right now.
You don't actually have to have it there, there's an option in my TechSupportForum profile 'do you want your specs listed? YES/NO' sort of thing..
I just think if we're going to have the feature it would be neater *shrug*
Re: NSFW Button
Postby BinnsY » 12 Jun 2008, 12:38
Personally I think it needs something other than the button. For example stef,, yours could quite easily fit onto one line and would in my opinion look better than the button.
Re: NSFW Button
Postby Johnmcl7 » 12 Jun 2008, 15:19
The button is easy to implement so that's the reason it's there, it's not meant to be a be all and end all solution. That said my personal preference is towards minimal signatures (I dislike signature images particularly although that's just a personal preference) and the button allows a more complex signature which is only there when needed. The button is not forced in any way though, it doesn't bypass any limits and it remains entirely up to the user's choice.
I have searched for any decent phpBB mods that would allow custom data (not necessarily PC specs) to be linked to from the user info panel where it makes sense but I've not been able to find that yet. There are custom profile fields which I didn't think was much use but I'm thinking looking at this page now if we could link to a little computer icon (similar to the PM, e-mail etc.) that could actually work well.
Return to “Site Discussion”
