Forum upgraded to version 3.0.10
Suggestions, thoughts and discussion on the forum setup
Postby Johnmcl7 » 18 May 2012, 01:29
I've finally managed to get around to upgrading the forum to the latest version of phpBB, we've been running the same version since the site launched mainly because it was a bit of a fiddle getting it onto the next one however it's done now and should hopefully be working ok. The main issue I'm aware of is with the styles, they overhauled how these worked in version 3.0.6 which means our style needs to be updated as well although I haven't found a straightforward way to do that yet. At the moment the obvious problem with it is the new captchas aren't working which is a bit frustrating as that was the main reason to upgrade but I'm hoping it will be fixable.
If you spot any bugs please use this topic to report them and hopefully we can get them sorted and once the forum is going well see if there's any new plugins worth sticking on now that we can add them.
Re: Forum upgraded to version 3.0.10
Postby matt » 18 May 2012, 08:06
internet points for John. Cheers boss!
Postby Johnmcl7 » 18 May 2012, 13:46
Also I think guest posting times are finally working properly!
Postby matt » 21 Jul 2012, 10:51
no problems here!
LtScunner
Has a Jaaaaaaaaaaaag
Postby LtScunner » 22 Jul 2012, 17:29
Everything has been fine in the limited time I've been back.
No problems to report
You're never alone with schizophrenia
Postby robbo » 23 Jul 2012, 23:34
Was that Matt's cheeky post for a full house above?!
oh, and *edit* all's working fine here too!! :D
Return to “Site Discussion”
