Roccat Power Grid - monitor hardware usage with a smartphone
Discuss PC and console gaming
Postby Johnmcl7 » 23 Oct 2013, 23:52
This looks a rather nifty piece of software that's just come into a free beta:
http://power-grid.roccat.org/en/Home/
You install the host software on your PC and then either the IOS/Android client on your phone and then you can monitor hardware usage and control some features of your PC. The reason I've put this in the gaming section is I'm thinking it could be particularly handy for checking out what your system is doing while gaming which is something I've been wanting to do for a while as I'm not sure what resources are being used. Annoyingly it doesn't seem to support my processor as it's limited to eight cores, it doesn't show the clock speed either and there's no GPU information. However aside from that it seems to work fine as it's installed without issue on my PC and phone, the controls for the PC seem to be working fine.
Return to “Gaming”
